Nagios Check result is wrong
supportagilita
Post by supportagilita »
Hi there,
I'm having issues with the new SLES15 checks / results.
Command used:
/usr/lib/nagios/plugins/check_disk -w 20% -c 10%
Expected result (check run local):
DISK CRITICAL - free space: /dev 440932 MB (100.00% inode=100%); /dev/shm 661410 MB (100.00% inode=100%); /run 440915 MB (99.99% inode=100%); /sys/fs/cgroup 440940 MB (100.00% inode=100%); / 24287 MB (83.27% inode=99%); /boot 936 MB (92.33% inode=100%); /usr/sap 45183 MB (73.57% inode=100%); /hana/log 367376 MB (89.73% inode=100%); /hana/data 277270 MB (45.15% inode=100%); /hana/backup 0 MB (0.00% inode=2%); /hana/shared 73598 MB (71.90% inode=100%); /sapmnt 28699 MB (93.46% inode=100%); /boot/efi 510 MB (99.79% inode=-); /hana/backup_long 2017597 MB (64.13% inode=-); /run/user/2001 88188 MB (100.00% inode=100%); /run/user/2000 88188 MB (100.00% inode=100%); /run/user/2002 88188 MB (100.00% inode=100%); /mnt/resource 876172 MB (89.52% inode=100%); /run/user/2003 88188 MB (100.00% inode=100%); /run/user/2004 88188 MB (100.00% inode=100%); /run/user/0 88188 MB (100.00% inode=100%);| /dev=0MB;352745;396838;0;440932 /dev/shm=0MB;529128;595269;0;661410 /run=25MB;352752;396846;0;440940 /sys/fs/cgroup=0MB;352752;396846;0;440940 /=4878MB;23332;26249;0;29166 /boot=77MB;811;912;0;1014 /usr/sap=16226MB;49128;55269;0;61410 /hana/log=42022MB;327519;368459;0;409399 /hana/data=336827MB;491278;552688;0;614098 /hana/backup=409406MB;327525;368466;0;409407 /hana/shared=28751MB;81880;92115;0;102350 /sapmnt=2005MB;24564;27634;0;30705 /boot/efi=1MB;408;459;0;511 /hana/backup_long=1128130MB;2516582;2831155;0;3145728 /run/user/2001=0MB;70550;79369;0;88188 /run/user/2000=0MB;70550;79369;0;88188 /run/user/2002=0MB;70550;79369;0;88188 /mnt/resource=102476MB;824874;927983;0;1031093 /run/user/2003=0MB;70550;79369;0;88188 /run/user/2004=0MB;70550;79369;0;88188 /run/user/0=0MB;70550;79369;0;88188
Result from nagios server:
/usr/local/nagios/libexec/check_nrpe -H <Client-IP> -c check_disks
DISK OK - free space: AggregateDisk 2355439 MB (71.41% inode=100%);| AggregateDisk=942671MB;2680450;3015506;0;3350563
Check disks is not the only check witch is giving wrong results.
Any suggestions ?
Thx for the help
benjaminsmith
Re: Nagios Check result is wrong
Post by benjaminsmith »
HI,
The command is slightly different, so I'd like to see the full command definition for check_disks in the nrpe.cfg file.
It looks like you have enable the group flag here that will apply to of all partitions together, for example:
./check_disk -w 10% -c 20% -g aggregate
