CSV Bandwidth Report in Human Readable format
rragha2
Post by rragha2 »
1. Can we download the bandwidth report in CSV Human Readable format. Now when i export to CSV it shows data in epoch format.
2. We have consolidate bandwidth report in single CSV file.
Nagios xi currently allows user to download as csv file one at a time, which is not practical for business.
Do we have a workaround for this.
Thank you for the support.
benjaminsmith
Re: CSV Bandwidth Report in Human Readable format
Post by benjaminsmith »
Thanks for trying out Nagios XI. Right now, it's not possible to consolidate reports, but you can add a group of bandwidth performance graphs from selected services to a common dashboard and then schedule the dashboard and send it as a PDF.
Understanding And Using Dashboards In Nagios XI
As far as the Unix timestamps from the CSV's, the best workaround right now would be to convert to a date time in Excel or another spreadsheet applications.
Let us know if you have more questions.
Benjamin
