Team,
we are trying to change thresholds for dead letters for service bus alerts in a server. But in configuration file, we can see only subscription messages thresholds and we are unable to find dead letters thresholds. where can we find configuration path for Dead letters .
please help us on this
unable to find configuration file
benjaminsmith
Re: unable to find configuration file
HI tchandra,
Can you post the full check command for this service so I can see the setting and plugin that you are using?
Thanks!
Benjamin
Thanks!
Benjamin
Hi Benjamin,
please find below command view
[root@**.**.**.** libexec]# ./check_nrpe -2 -H **.**.**.** -t 120 -c check_ServiceBus_tal.integration.azure.svcbus.ewf.workflowfacade_ArchiveEWFUpsert
Service Bus OK - Subscription 'tal.integration.azure.svcbus.ewf.workflowfacade/ArchiveEWFUpsert' messages: 726, dead letters: 0|Messages=726;35000;40000
|Deadletters=0;1;3
In the above output, You can see defined thresholds values and current values of messages and dead letters . we changed threshold values in windows server nsc custom file, it changed messages only. but we are unable to find where can we change thresholds for dead letters.
thanks for response.
Thanks & regards,
Chandra
|Deadletters=0;1;3
Thanks & regards,
Chandra
