Hi
i upgraded test environment from 5.6.14 -> 5.7.2. The test environment nagios locahost check are all good, but when monitoring the test nagiosxi instance from live with Nagios XI server service checks, i get 2 alarms after upgrade:
Nagios XI Jobs - No job information found.
Nagios XI Daemons - No daemon information found.
From earlier posts i could read that its safe to ignore ndo2db alarms after upgrade, but how about the 2 above?
Thank you!
nagios upgrade question
benjaminsmith
Re: nagios upgrade question
Those should be working and showing green. If you go to Admin > System Information > System Status is everything running or green.
If so, try re-running the Nagios XI Server wizard. And if not, try rebooting the server and let me know if the services come back up.
Hi
Under system information everything was green. Deleted the service checks and added again and now all show OK.
Thank you.
Thank you.
Glad to hear it is workingelinagios wrote:Hi
Thank you.
Locking thread
