check_http and skip client challenge?
brandondash
Post by brandondash »
Is there a way to do this? In our environment we won't be able to convince our CA to give us a client token just so we can do health checks of our web servers (who all run 2 way SSL). I don't need to get any results from the GET request. I just need to know that a connection is being established. As it stands I end up with the standard Socket Timeout.
cdienger
Re: check_http and skip client challenge?
Post by cdienger »
If you're just looking to verify that a tcp connection can be made on the port then you could use the check_tcp plugin instead.
