I am running NLS version 2.1.7 on Ubuntu. Under Admin-Global Settings, I change the cluster timezone setting to Eastern Time and it looks like the setting change saves. But when I go out of that screen and go back into it, the timezone always shows Midway Island as the TZ.
Please let me know how I can get the timezone changed.
Ron
Cluster Timezone Change Not Saving
Re: Cluster Timezone Change Not Saving
This was an issue on previous versions but I'm not able to reproduce it on the current 2.1.7 version. What version of Ubuntu is this? Also double check the NLS version by running this on the command line:
Does it show the correct timezone if you run the 'date' command on the command line?
cat /var/www/html/nagioslogserver/lsversionAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
rfinnertyimp
We are running Ubuntu 18.04.4 LTS
NLS Version- VERSION=2107
I verified this server has the correct timezone.
I do want to note that we upgraded from version 2.1.6, so it was not a clean installation of 2.1.7
Ron
Ron
Thanks for confirming. I've been able to reproduce and will file a bug for this so that it can be addressed in the next release.
rfinnertyimp
Great- thanks
Ron
Ron
Locking threadrfinnertyimp wrote:Great- thanks
Ron
