Nagios xi change default account for ssh_proxy
btaylorjr
Post by btaylorjr »
is their a way to change the default account for the ssh_proxy to a difrant account The"nagios" account does not match our user policy for names
cdienger
Re: Nagios xi change default account for ssh_proxy
Post by cdienger »
Welcome to the forum, @btaylorjr!
Do you mean the check_by_ssh plugin? If so, then you can use a different login. First, transfer the key over to the account on the remote machine:
ssh-copy-id -i ~/.ssh/id_rsa.pub [email protected]
and then use the "-l" option with the check_by_ssh plugin to specify the account:
/usr/local/nagios/libexec/check_by_ssh -H 192.168.55.3 -l bob -C uptime
These are small changes to the same commands that https://assets.nagios.com/downloads/nag ... ng_SSH.pdf outlines.
