After upgrading from version 5.6.14 to version 5.7.2, we are running issue in reports. We can successfully run the report but when we try to download .pdf or .csv, It error out as (Attachment).
Somehow the link to the report change to localhost.localdomain. And the generated report can't be downloaded. We didn't have this issue in the older version.
Nish
report download issue after upgrade-
Re: report download issue after upgrade-
Ticket open for the same issue, problem will be worked in ticket
Locking thread
Locking thread
