Nagios KPI addons
CSOST
Nagios KPI addons
Post by CSOST »
I'm trying to find out any info that can give KPI report from Nagios, the only thing i found out is a PDF from 2014 on google , otherwise there is no plugin or a way to create general report of all info from nagios - for example KPI for all CPUs or Capacity planning for the entire system and no 200 pages.
anyone know a way or a dashlet that can show summaries KPI from all the logs ?
for example KPI Dashboard Component
thank you
benjaminsmith
Re: Nagios KPI addons
Post by benjaminsmith »
Hi @CSOST,
This is a great question, and while there's not a default KPI dashboard you can certainly create your own version of this dashboard available with the available dashlets.
Take a look at the Metrics component, Home > Details > Metrics, you'll find summaries of check results along with performance graphs that are very useful.
Reference:
Understanding And Using Dashboards In Nagios XI
