How to monitor DB backup failure using NCPA wizard
swarna1986
Post by swarna1986 »
Hello All,
I need help for monitoring the following in Nagios XI tool using NCPA wizard.
• Data file full
• Tempdb full
• Blocking
• Deadlock
• Job failure
• DB Backup failure
• Backup device failure
• DB Restore failure
• Always On Availability Group status
• New database creation
• Database offline/suspect/recovery/restoring mode
• Login failure
• User account lock/expiry
• Average Lock wait time
DB Instance level Monitoring
• All the cluster/Always On Nodes are active/healthy
• SQL Server Browser
• SQL Full-text Filter Daemon Launcher
Thanks and Regards
Swarna
Re: How to monitor DB backup failure using NCPA wizard
We have several database wizards that can monitor many of these, which have you tried? (not sure that the NCPA wizard is the best option)
swarna1986
Hello Scott
Thanks for your reply
Could you please tell me what all wizards can be used for DB monitoring in detail.
If you click
Configure -> Configuration Wizards
There is a database icon (5th from the left), click that and all the database wizards will appear
