Nagios Network Analyzer service is not starting
Re: Nagios Network Analyzer service is not starting
Did you setup a source?
If yes, can you post the output of the following
tail -50 /usr/local/nagiosna/var/backend.log
otherwise, you need to add a source before the nagiosna service can start
netservllc wrote:No. I haven't added a source
I didn't see anything mentioned about it in the installation steps.
I just installed nagiosna by running this script on a fresh ubuntu server
curl https://assets.nagios.com/downloads/nag ... install.sh | sh
Please can you tell me how to add a source?
It's more about the usage that installation.
Here's a doc that goes over adding sources
https://assets.nagios.com/downloads/nag ... alyzer.pdf
