I may have jumped the gun slightly with thinking my last post was resolved sorry!
Attempting to upgrade to 5.7.3 (from 5.6.9) via the manual download process as suggested but it doesn't appear to be working
When i run ./upgrade I run into this error:
Error: Package: nagiosxi-deps-el7-5.7.3-1.noarch (/nagiosxi-deps-el7-5.7.3-1.noarch)
Requires: git
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
but that dependency appears to be installed (currently running git 2.28)
Am i misinterpreting what the error is telling me?
any guidance appreciated
Upgrade to 5.7.3 failure due to dependency
Re: Upgrade to 5.7.3 failure due to dependency
What do you get when rinning the following
yum list installed |grep gitRe: Upgrade to 5.7.3 failure due to dependency
i get the following:
and if I run git --version i get
git version 2.28.0
crontabs.noarch 1.11-6.20121102git.el7 @anaconda
linux-firmware.noarch 20180220-62.2.git6d51311.el7_5 @updates
lm_sensors-devel.x86_64 3.4.0-4.20160601gitf9185e5.el7 @base
lm_sensors-libs.x86_64 3.4.0-4.20160601gitf9185e5.el7 @base
git version 2.28.0
This would mean that you installed git outside of the package management system.IPOInS wrote:i get the following:
crontabs.noarch 1.11-6.20121102git.el7 @anaconda linux-firmware.noarch 20180220-62.2.git6d51311.el7_5 @updates lm_sensors-devel.x86_64 3.4.0-4.20160601gitf9185e5.el7 @base lm_sensors-libs.x86_64 3.4.0-4.20160601gitf9185e5.el7 @base
git version 2.28.0
Being git is part of the base repository I'm more concerned why this wouldn't be available
it appears we've switched to not allowing direct connection to the centos base repo and switched to an internal mirror.
explains why it can't find it! hopefully introducing said repo will help, though If git Is install regardless (outside of this) does it still not meet the dependency requirement? or is the upgrade specifically looking at the repo's installed list to meet said requirement?
The upgrade expects to be able to find the package requirements it needs in the base, epel and nagios repositoriesIPOInS wrote:it appears we've switched to not allowing direct connection to the centos base repo and switched to an internal mirror.
