Hi there,
We are running Nagios XI 5.7.3 on Centos 7. Database service is running on Centos 8 with MariaDB 10.5.
On Monitoring Engine Status the Monitoring Engine Performance shows statistics while Monitoring Engine Check Statistics is empty.
No errors are logged. You may find the system profile attached.
Re: Monitoring Engine Check Statistics is empty
The statistics where correctly empty as the nagios service (while active) had stopped sending checks. After a reboot it started showing stats again.
You may close this post.
Great!taxidis wrote:The statistics where correctly empty as the nagios service (while active) had stopped sending checks. After a reboot it started showing stats again.
Locking thread
