I have successfully made it to the last command on the online server, and it appears to successfully complete, but there is no output nor any pipfiles in the designated location. please see below:
sudo grep '\$pipbin install' upgrade | sed 's/\$pipbin install --upgrade/pip download -d \/var\/satellite\/nagios-upgrade\/pipfiles\//' | source /dev/stdin
[tsiluser@repo nagios-upgrade]$
cd pipfiles/
[tsiluser@repo pipfiles]$ ll
total 0
Offline Upgrade Will not Download pipfiles
Re: Offline Upgrade Will not Download pipfiles
Try breaking it down a bit:
which should show you lines with 'pip install'
and then run:
which should show you what command(s) it will attempt to run to download the file. Use this output to try and run the pip command manually. I suspect there may be an issue with the command and the installed version of pip. Check the version with:
grep 'pip install' upgradeand then run:
grep 'grep 'pip install' upgrade | sed 's/pip install --upgrade/pip download -d \/tmp\/pipfiles\//'
pip --versionAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
