Bulk deletion hosts from Nagiosxi
mejokj
Post by mejokj »
Hi Team,
We need to delete 56 hosts from Nagiosxi. Is there anyway we can delete these 56 hosts as bulk from Nagiosxi.
Please suggest.
cdienger
Re: Bulk deletion hosts from Nagiosxi
Post by cdienger »
Depending on the configuration and version of XI, you _may_ be able to delete the hosts all at one time by going to Configure > Core Config Manager > Monitoring > Hosts, selecting all the hosts you want to delete, and then selecting delete from the 'with checked' drop-down menu. If there are any conflicts with removing a host and its services it should give you an error message indicating where the problem is at.
