Nagios XI version: 5.7.3
Red Hat Enterprise Linux Server release 7.8 (Maipo)
When I go to BBMap - nothing shows up
So I went to CCM > Services - nothing shows up - but says "Displaying 1-15 of 7314 results".
So I went to Config file management - and went through the "delete files" - "write files" - then "verify files" - and got this.
Error: Unable to write to temp_path ('/tmp') - No such file or directory
Nagios Core 4.4.6
Last Modified: 2020-04-28
License: GPL
I looked at /tmp - drwxrwxrwt. 7 root root 118 Sep 14 09:20 tmp
I looked at vi /usr/local/nagios/etc/nagios.cfg - tmp is set to /tmp
What am I missing?
Reading configuration data...
Read main config file okay...
Checking objects...
Checked 7281 services.
Checked 1068 hosts.
Checked 2 host groups.
Checked 14 service groups.
Checked 19 contacts.
Checked 16 contact groups.
Checked 139 commands.
Checked 24 time periods.
Checked 0 host escalations.
Checked 1068 hosts
Checked 0 host dependencies
Checked 24 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors: 1
seaward1983
seaward1983
Re: Error: Unable to write to temp_path ('/tmp') - No such f
I got rid of "Error: Unable to write to temp_path ('/tmp') - No such file or directory" this error by totally restarting Nagios - but still getting nothing when I do this:
I tailed the nagios.log - and see this - but don't know what it means - or if it's even related:
[1600098484] NDO-3: Database initialized
[1600098484] NDO-3: Unable to prepare statement for query (5): Table './nagios/nagios_logentries' is marked as crashed and last (automatic?) repair failed
[1600098484] NDO-3: Error preparing statements
seaward1983
I love it when a plan comes together -- so I did this
/usr/local/nagiosxi/scripts/repair_databases.sh
And now everything is showing up.
Thank you for playing, please tip your waiters and waitresses on your way out.
Glad you were able to get the DB repaired and everything sorted outseaward1983 wrote:I love it when a plan comes together -- so I did this
Locking thread
