After a offline upgrade from 5.5.9 to 5.7.3 on RHEL 7 the monitor engine does not work, i tried to restart the service but the monitor engine goes red after 2 minutes.
i have already restart the nagios service. i checked the nagios log error and i get the following info.
[1600091657] NDO-3: ndo_handle_service_status(ndo-handlers.c:953): Could not reconnect to MySQL database
[1600091658] NDO-3: Unable to prepare statement for query (27): Unknown column 'check_options' in 'field list'
[1600091658] NDO-3: Unable to prepare statement for query (28): Unknown column 'check_options' in 'field list'
[1600091658] NDO-3: Error preparing statements
Can you help me please?
Monitor engine does not work after upgrade from 5.5.9 to 5.7
tatianagraciap
Re: Monitor engine does not work after upgrade from 5.5.9 to
It seems like a portion of the database may not have updated as expected
Lets' connect to mysql (if you change dthe mysql rppt password replace nagiosxi below with that password
Then lets execute the following code
After this exit mysql
and restart nagios
mysql -pnagiosxi nagiosCode: Select all
# Add the column 'check_options' to nagios_servicestatus if it doesn't already exist
SET @exist := (SELECT COUNT(*) FROM `information_schema`.`columns` WHERE table_name = 'nagios_servicestatus' AND column_name = 'check_options');
SET @sqlstmt := if( @exist <= 0,
'ALTER TABLE `nagios_servicestatus` ADD `check_options` smallint(6) NOT NULL default ''0'' AFTER `check_type`',
'select ''INFO: Column already exists.''');
PREPARE stmt FROM @sqlstmt;
EXECUTE stmt;
# Add the column 'check_options' to nagios_hoststatus if it doesn't already exist
SET @exist := (SELECT COUNT(*) FROM `information_schema`.`columns` WHERE table_name = 'nagios_hoststatus' AND column_name = 'check_options');
SET @sqlstmt := if (@exist <= 0,
'ALTER TABLE `nagios_hoststatus` ADD `check_options` smallint(6) NOT NULL default ''0'' AFTER `check_type`',
'SELECT ''INFO: Column already exists.''');
EXECUTE stmt;
ALTER TABLE nagios_objects MODIFY name1 VARCHAR(1023) CHARACTER SET utf8 COLLATE utf8_bin;
ALTER TABLE nagios_objects MODIFY name2 VARCHAR(1023) CHARACTER SET utf8 COLLATE utf8_bin;Code: Select all
exitCode: Select all
systemctl restart nagios
