Im trying to figure out the best way to monitor AD server with NCPA 2.2 , currently i find that NRPE do have a string to check Active directory services
" check_activedir " .
check_nrpe -H $HOSTADDRESS$ -t 30 -c $ARG1$ $ARG2$
how do u set the ARG under NCPA in this case ?
Thank you
Monitor Active directory using NCPA
Re: Monitor Active directory using NCPA
Instead of defining a command on the NRPE client side to execute check_activedir, you would simply place the plugin in NCPA's plugin directory and execute it with something like:
https://support.nagios.com/kb/article/n ... a-722.html covers how to execute a plugin with NCPA as well as creating the service on XI.
./check_ncpa.py -H <client_ip> -t '<your token>' -M 'plugins/check_activedir' -q ''
Thank you cdienger for your help
Glad we could helpCSOST wrote:Thank you cdienger for your help
Locking thread
