Can you please help us understand switch monitoring>
tbellinger
Post by tbellinger »
We are testing Nagios XI and find the server monitoring is excellent.
Unfortunately we are having trouble monitoring an Ethernet switch.
1. We are unable to see device availability, CPU utilisation or memory utilisation. What do we need to do to get this information?
2. In addition, we get weird and wonderful port names. What can we do to import more meaningful names … e.g. Port 1, Port 2 etc.
Please find below the output we have so far.
Many thanks - Tarquin belling
swt01
Ping
Ok 7m 47s 1/5 01/07/2010 18:20:14 OK - hmsp-syd-noc-swt-01: rta 0.778ms, lost 0%
Port 10103 Bandwidth
Ok 7m 36s 1/5 01/07/2010 18:20:25 OK - Current BW in: .01Mbps Out: .01Mbps
Port 10103 Status
Ok 7m 26s 1/5 01/07/2010 18:20:35 OK: Interface GigabitEthernet0/3 (index 10103) is up.
Port 10105 Bandwidth
Ok 7m 15s 1/5 01/07/2010 18:20:46 OK - Current BW in: 0Mbps Out: 0Mbps
Port 10105 Status
Ok 7m 5s 1/5 01/07/2010 18:20:56 OK: Interface GigabitEthernet0/5 (index 10105) is up.
Port 10107 Bandwidth
Ok 6m 54s 1/5 01/07/2010 18:21:07 OK - Current BW in: 0Mbps Out: 0Mbps
Port 10107 Status
Ok 6m 44s 1/5 01/07/2010 18:21:17 OK: Interface GigabitEthernet0/7 (index 10107) is up.
Port 10108 Bandwidth
Ok 6m 33s 1/5 01/07/2010 18:21:28 OK - Current BW in: 0Mbps Out: 0Mbps
Port 10108 Status
Ok 6m 23s 1/5 01/07/2010 18:21:38 OK: Interface GigabitEthernet0/8 (index 10108) is up.
Port 10110 Bandwidth
Ok 6m 12s 1/5 01/07/2010 18:21:49 OK - Current BW in: .18Mbps Out: 1.51Mbps
Port 10110 Status
Ok 6m 2s 1/5 01/07/2010 18:21:59 OK: Interface GigabitEthernet0/10 (index 10110) is up.
Port 10113 Bandwidth
Ok 5m 51s 1/5 01/07/2010 18:22:10 OK - Current BW in: 0Mbps Out: 0Mbps
Port 10113 Status
Ok 5m 41s 1/5 01/07/2010 18:22:20 OK: Interface GigabitEthernet0/13 (index 10113) is up.
Port 10114 Bandwidth
Ok 5m 30s 1/5 01/07/2010 18:22:31 OK - Current BW in: 0Mbps Out: 0Mbps
Port 10114 Status
Ok 5m 20s 1/5 01/07/2010 18:22:41 OK: Interface GigabitEthernet0/14 (index 10114) is up.
Port 10115 Bandwidth
Ok 5m 9s 1/5 01/07/2010 18:22:52 OK - Current BW in: 0Mbps Out: .07Mbps
Port 10115 Status
Ok 4m 58s 1/5 01/07/2010 18:18:03 OK: Interface GigabitEthernet0/15 (index 10115) is up.
Port 10117 Bandwidth
Ok 4m 48s 1/5 01/07/2010 18:18:13 OK - Current BW in: 0Mbps Out: 0Mbps
Port 10117 Status
Ok 4m 37s 1/5 01/07/2010 18:18:24 OK: Interface GigabitEthernet0/17 (index 10117) is up.
Port 10118 Bandwidth
Ok 4m 27s 1/5 01/07/2010 18:18:34 OK - Current BW in: 0Mbps Out: 0Mbps
Port 10118 Status
Ok 4m 16s 1/5 01/07/2010 18:18:45 OK: Interface GigabitEthernet0/18 (index 10118) is up.
Port 10119 Bandwidth
Ok 4m 6s 1/5 01/07/2010 18:18:55 OK - Current BW in: 0Mbps Out: 0Mbps
Port 10119 Status
Ok 3m 55s 1/5 01/07/2010 18:19:06 OK: Interface GigabitEthernet0/19 (index 10119) is up.
Port 10120 Bandwidth
Ok 3m 45s 1/5 01/07/2010 18:19:16 OK - Current BW in: 0Mbps Out: 0Mbps
Port 10120 Status
Ok 3m 34s 1/5 01/07/2010 18:19:27 OK: Interface GigabitEthernet0/20 (index 10120) is up.
Port 10133 Bandwidth
Ok 3m 24s 1/5 01/07/2010 18:19:37 OK - Current BW in: 0Mbps Out: 0Mbps
Port 10133 Status
Ok 3m 13s 1/5 01/07/2010 18:19:48 OK: Interface GigabitEthernet0/33 (index 10133) is up.
Port 10137 Bandwidth
Ok 7m 3s 1/5 01/07/2010 18:20:58 OK - Current BW in: 0Mbps Out: 0Mbps
Port 10137 Status
Ok 7m 52s 1/5 01/07/2010 18:20:09 OK: Interface GigabitEthernet0/37 (index 10137) is up.
Port 10138 Bandwidth
Ok 7m 42s 1/5 01/07/2010 18:20:19 OK - Current BW in: 0Mbps Out: 0Mbps
Port 10138 Status
Ok 7m 31s 1/5 01/07/2010 18:20:30 OK: Interface GigabitEthernet0/38 (index 10138) is up.
Port 10139 Bandwidth
Ok 7m 21s 1/5 01/07/2010 18:20:40 OK - Current BW in: 0Mbps Out: 0Mbps
Port 10139 Status
Ok 7m 10s 1/5 01/07/2010 18:20:51 OK: Interface GigabitEthernet0/39 (index 10139) is up.
Port 10140 Bandwidth
Ok 7m 0s 1/5 01/07/2010 18:21:01 OK - Current BW in: 0Mbps Out: 0Mbps
Port 10140 Status
Ok 6m 49s 1/5 01/07/2010 18:21:12 OK: Interface GigabitEthernet0/40 (index 10140) is up.
Port 10141 Bandwidth
Ok 6m 38s 1/5 01/07/2010 18:21:23 OK - Current BW in: 0Mbps Out: .01Mbps
Port 10141 Status
Ok 6m 28s 1/5 01/07/2010 18:21:33 OK: Interface GigabitEthernet0/41 (index 10141) is up.
Port 10143 Bandwidth
Ok 6m 17s 1/5 01/07/2010 18:21:44 OK - Current BW in: 1.84Mbps Out: 1.10Mbps
Port 10143 Status
Ok 6m 7s 1/5 01/07/2010 18:21:54 OK: Interface GigabitEthernet0/43 (index 10143) is up.
Port 10144 Bandwidth
Ok 5m 56s 1/5 01/07/2010 18:22:05 OK - Current BW in: .19Mbps Out: 2.51Mbps
Port 10144 Status
Ok 5m 46s 1/5 01/07/2010 18:22:15 OK: Interface GigabitEthernet0/44 (index 10144) is up.
Port 10145 Bandwidth
Ok 5m 35s 1/5 01/07/2010 18:22:26 OK - Current BW in: .11Mbps Out: .18Mbps
Port 10145 Status
Ok 5m 25s 1/5 01/07/2010 18:22:36 OK: Interface GigabitEthernet0/45 (index 10145) is up.
Port 10148 Bandwidth
Ok 5m 14s 1/5 01/07/2010 18:22:47 OK - Current BW in: 5.37Mbps Out: 2.34Mbps
Port 10148 Status
Ok 5m 4s 1/5 01/07/2010 18:17:57 OK: Interface GigabitEthernet0/48 (index 10148) is up.
Port 40 Bandwidth
Ok 4m 53s 1/5 01/07/2010 18:18:08 OK - Current BW in: 0Mbps Out: 0Mbps
Port 40 Status
Ok 4m 43s 1/5 01/07/2010 18:18:18 OK: Interface Vlan40 (index 40) is up.
Port 5001 Bandwidth
Ok 4m 32s 1/5 01/07/2010 18:18:29 OK - Current BW in: 0Gbps Out: 0Gbps
Port 5001 Status
Ok 4m 22s 1/5 01/07/2010 18:18:39 OK: Interface Port-channel1 (index 5001) is up.
tonyyarusso
Re: Can you please help us understand switch monitoring>
Post by tonyyarusso »
Switch information is generally obtained through SNMP. Some or all of it may be restricted to only allowed hosts, so you may need to use your switch's configuration interface to make sure the Nagios server is allowed to "see" the information you want. The naming scheme should also be passed from the switch, although if you can't change that on the hardware you can at least rename the Nagios services after the fact. You'll likely find more information in the user manual for your specific model of network switch, particularly if there's a section on SNMP access.
Tony Yarusso
Technical Services
___
TIES
Web: http://ties.k12.mn.us/
