We experienced a major issue with our vSphere environment yesterday and since then one of our Log Server nodes has logstash service issues.
For some reason, it keeps switching it's status to Active (exited) despite my best efforts to keep it running. Everything in the environment looks okay except for this one problem.
root@nagioslscc3:/var>/usr/bin/java -XX:+UseParNewGC -XX:+UseConcMarkSweepGC -Djava.awt.headless=true -XX:CMSInitiatingOccupancyFraction=75 -XX:+UseCMSInitiatingOccupancyOnly -XX:+HeapDumpOnOutOfMemoryError -Djava.io.tmpdir=/usr/local/nagioslogserver/tmp -Xmx500m -Xss2048k -Djffi.boot.library.path=/usr/local/nagioslogserver/logstash/vendor/jruby/lib/jni -XX:+UseParNewGC -XX:+UseConcMarkSweepGC -Djava.awt.headless=true -XX:CMSInitiatingOccupancyFraction=75 -XX:+UseCMSInitiatingOccupancyOnly -XX:+HeapDumpOnOutOfMemoryError -Djava.io.tmpdir=/usr/local/nagioslogserver/tmp -XX:HeapDumpPath=/usr/local/nagioslogserver/logstash/heapdump.hprof -Xbootclasspath/a:/usr/local/nagioslogserver/logstash/vendor/jruby/lib/jruby.jar -classpath : -Djruby.home=/usr/local/nagioslogserver/logstash/vendor/jruby -Djruby.lib=/usr/local/nagioslogserver/logstash/vendor/jruby/lib -Djruby.script=jruby -Djruby.shell=/bin/sh org.jruby.Main --1.9 /usr/local/nagioslogserver/logstash/lib/bootstrap/environment.rb logstash/runner.rb agent -f /usr/local/nagioslogserver/logstash/etc/conf.d -l /var/log/logstash/logstash.log -w 4
Sending logstash logs to /var/log/logstash/logstash.log.
Settings: User set pipeline workers: 4, Default pipeline workers: 12
Exception in thread "pipeline.main" java.nio.BufferOverflowException
at java.nio.HeapByteBuffer.put(HeapByteBuffer.java:194)
at org.jruby.util.io.ChannelStream.bufferedWrite(ChannelStream.java:1100)
at org.jruby.util.io.ChannelStream.fwrite(ChannelStream.java:1277)
at org.jruby.RubyIO.fwrite(RubyIO.java:1560)
at org.jruby.RubyIO.write(RubyIO.java:1431)
at org.jruby.RubyIO$INVOKER$i$1$0$write.call(RubyIO$INVOKER$i$1$0$write.gen)
at org.jruby.RubyClass.finvoke(RubyClass.java:743)
at org.jruby.runtime.Helpers.invoke(Helpers.java:505)
at org.jruby.RubyBasicObject.callMethod(RubyBasicObject.java:364)
at org.jruby.RubyIO.write(RubyIO.java:2509)
at org.jruby.RubyIO.putsSingle(RubyIO.java:2497)
at org.jruby.RubyIO.puts1(RubyIO.java:2426)
at org.jruby.RubyIO.puts(RubyIO.java:2399)
at org.jruby.RubyIO$INVOKER$i$puts.call(RubyIO$INVOKER$i$puts.gen)
at org.jruby.runtime.callsite.CachingCallSite.call(CachingCallSite.java:168)
at org.jruby.ast.CallOneArgNode.interpret(CallOneArgNode.java:57)
at org.jruby.ast.NewlineNode.interpret(NewlineNode.java:105)
at org.jruby.ast.BlockNode.interpret(BlockNode.java:71)
at org.jruby.ast.IfNode.interpret(IfNode.java:116)
at org.jruby.evaluator.ASTInterpreter.INTERPRET_BLOCK(ASTInterpreter.java:112)
at org.jruby.runtime.Interpreted19Block.evalBlockBody(Interpreted19Block.java:206)
at org.jruby.runtime.Interpreted19Block.yield(Interpreted19Block.java:157)
at org.jruby.runtime.Block.yield(Block.java:142)
at org.jruby.ext.thread.Mutex.synchronize(Mutex.java:149)
at org.jruby.ext.thread.Mutex$INVOKER$i$0$0$synchronize.call(Mutex$INVOKER$i$0$0$synchronize.gen)
at org.jruby.runtime.callsite.CachingCallSite.callBlock(CachingCallSite.java:143)
at org.jruby.runtime.callsite.CachingCallSite.callIter(CachingCallSite.java:154)
at org.jruby.ast.CallNoArgBlockNode.interpret(CallNoArgBlockNode.java:64)
at org.jruby.evaluator.ASTInterpreter.INTERPRET_METHOD(ASTInterpreter.java:74)
at org.jruby.internal.runtime.methods.InterpretedMethod.call(InterpretedMethod.java:182)
at org.jruby.internal.runtime.methods.DefaultMethod.call(DefaultMethod.java:203)
at org.jruby.runtime.callsite.ShiftLeftCallSite.call(ShiftLeftCallSite.java:24)
at org.jruby.RubyHash$13.visit(RubyHash.java:1355)
at org.jruby.RubyHash.visitLimited(RubyHash.java:648)
at org.jruby.RubyHash.visitAll(RubyHash.java:634)
at org.jruby.RubyHash.iteratorVisitAll(RubyHash.java:1306)
at org.jruby.RubyHash.each_pairCommon(RubyHash.java:1351)
at org.jruby.RubyHash.each19(RubyHash.java:1342)
at org.jruby.RubyHash$INVOKER$i$0$0$each19.call(RubyHash$INVOKER$i$0$0$each19.gen)
at org.jruby.ast.FCallOneArgNode.interpret(FCallOneArgNode.java:36)
at org.jruby.internal.runtime.methods.InterpretedMethod.call(InterpretedMethod.java:225)
at org.jruby.internal.runtime.methods.DefaultMethod.call(DefaultMethod.java:219)
at org.jruby.runtime.callsite.CachingCallSite.cacheAndCall(CachingCallSite.java:346)
at org.jruby.runtime.callsite.CachingCallSite.call(CachingCallSite.java:204)
at org.jruby.ast.FCallTwoArgNode.interpret(FCallTwoArgNode.java:38)
at org.jruby.internal.runtime.methods.InterpretedMethod.call(InterpretedMethod.java:268)
at org.jruby.internal.runtime.methods.DefaultMethod.call(DefaultMethod.java:235)
at org.jruby.runtime.callsite.CachingCallSite.cacheAndCall(CachingCallSite.java:366)
at org.jruby.runtime.callsite.CachingCallSite.call(CachingCallSite.java:238)
at org.jruby.ast.FCallThreeArgNode.interpret(FCallThreeArgNode.java:40)
at org.jruby.runtime.Interpreted19Block.yield(Interpreted19Block.java:194)
at org.jruby.runtime.Interpreted19Block.call(Interpreted19Block.java:125)
at org.jruby.runtime.Block.call(Block.java:101)
at org.jruby.RubyProc.call(RubyProc.java:300)
at org.jruby.internal.runtime.methods.ProcMethod.call(ProcMethod.java:64)
at org.jruby.internal.runtime.methods.DynamicMethod.call(DynamicMethod.java:218)
at org.jruby.internal.runtime.methods.DynamicMethod.call(DynamicMethod.java:214)
at org.jruby.ast.CallTwoArgNode.interpret(CallTwoArgNode.java:59)
at org.jruby.ast.RescueBodyNode.interpret(RescueBodyNode.java:108)
at org.jruby.ast.RescueNode.handleException(RescueNode.java:174)
at org.jruby.ast.RescueNode.interpret(RescueNode.java:120)
at org.jruby.ast.BeginNode.interpret(BeginNode.java:83)
at org.jruby.RubyProc.call(RubyProc.java:230)
at org.jruby.internal.runtime.RubyRunnable.run(RubyRunnable.java:99)
at java.lang.Thread.run(Thread.java:748)
When I ran it the first time, there was an I/O error saying that /var was out of space. I'm trying to figure out what's causing that as it does appear to be the case:
I went through the various directories inside of /var and the one thing that jumped out at me is the current elasticseach .log file on the node I'm having trouble with is 2.8GBs while the other nodes are only about 4MBs.
I think if we can clear out that log file and start a new one, that might correct the issue with the logstash service.
I can't get a system profile, because the node won't let me login to it.
