Sep 16 11:49:08 XXXXXXXXXXXXXXXXXXXX rrdcached[6547]: queue_thread_main: rrd_update_r (/usr/local/nagios/share/perfdata/XXXXXXXXXXXXXXXXXXXX /Disk_Usage_on__dev_mapper_vg00-var.rrd) failed with status -1. (/usr/local/nagios/share/perfdata/XXXXXXXXXXXXXXXXXXXX /Disk_Usage_on__dev_mapper_vg00-var.rrd: found extra data on update argument: 3.03:4.86)
Sep 16 11:49:09 XXXXXXXXXXXXXXXXXXXX rrdcached[6547]: queue_thread_main: rrd_update_r (/usr/local/nagios/share/perfdata/XXXXXXXXXXXXXXXXXXXX /Disk_Usage_on__dev_mapper_vg00-opt.rrd) failed with status -1. (/usr/local/nagios/share/perfdata/XXXXXXXXXXXXXXXXXXXX /Disk_Usage_on__dev_mapper_vg00-opt.rrd: found extra data on update argument: 0.69:0.95)
Sep 16 11:49:10 XXXXXXXXXXXXXXXXXXXX rrdcached[6547]: queue_thread_main: rrd_update_r (/usr/local/nagios/share/perfdata/XXXXXXXXXXXXXXXXXXXX /_HOST_.rrd) failed with status -1. (/usr/local/nagios/share/perfdata/XXXXXXXXXXXXXXXXXXXX /_HOST_.rrd: expected 4 data source readings (got 1) from 1600270238)
We are running Nagios XI 5.6.10 on RHEL 7 VMs. Offloaded database with rrdcached 1.4.4
Did you change the command for these to return a different quantity of performance data that was there before? It seems you are getting a different amount of perfdata that the RRDs expect
