NagVis not working JSON error
odino2016
Post by odino2016 »
Hi All,
we're performing a upgrade from nagvis 1.5 to the latest bundled with NagiosXI 5.7.3
OS RHEL 8.2
NAGIOSXI 5.7.3
I've upgraded Nagvis using the Upgrade scripts without errors but if I try to see our maps the results is always a json error.
The OS is clean and nagiosxi has been installed using the 5.7.2 then upgraded to the 5.7.3 (host, services and so on have been imported from a nagios 5.4.2)
Nagvis 1.5 has been copied from the same NagiosXI 5.4.2 used to import nagios core configs and then upgraded to the latest bundled with NagiosXI 5.7.3
Note: Actually all the HOSTS and SERVICES are in downtime.
TIA for the support.
cdienger
Re: NagVis not working JSON error
Post by cdienger »
I'd like to get a profile from the XI server which can be generated under Admin > System Config > System Profile > Download Profile, or from the command line with:
/usr/local/nagiosxi/scripts/components/getprofile.sh 60119
The profile is then saved to:
/usr/local/nagiosxi/var/components/profile.zip
I'd also like to get a copy of a the database that has the current configuration. If the default database is being used then this can be done from the command line with:
mysqldump -uroot -pnagiosxi nagiosql > nagiosql.sql
Finally, please provide me a copy of the /usr/local/nagvis directory.
Send all three pieces of data to me through a PM.
