I would like to graph the availability of hosts in grafana. I would use the output of check_icmp or check_ping commands, but the return is "OK". Anyone knows how I can turn this "OK" in percentage? 100% for up and 0% for down so I can graph it?
Thank you
Change OK to metric
Re: Change OK to metric
check_ping should return performance data where the pl metric is what you are looking for, it shows the percent of packet loss
Packet loss is not exactly availability. I understand what you say, but if I lose 1 ping out of 3, it is not unavailability, but it is packet loss. I want to graph the availability, not the pl that might occur if I lose 1 ping packet out of 3 or 5, which I test in every check.scottwilkerson wrote:check_ping should return performance data where the pl metric is what you are looking for, it shows the percent of packet loss
How are you sending the data to Grafana?coitop wrote:Packet loss is not exactly availability. I understand what you say, but if I lose 1 ping out of 3, it is not unavailability, but it is packet loss. I want to graph the availability, not the pl that might occur if I lose 1 ping packet out of 3 or 5, which I test in every check.scottwilkerson wrote:check_ping should return performance data where the pl metric is what you are looking for, it shows the percent of packet loss
