NagiosXI Web Interface not working after Ndoutils installed
amitshastri
Post by amitshastri »
I installed Ndoutils and after doing so I am getting an error message. The message says there is a Database Error and to try and run a script. I run the script and it goes through 3 databases however only 1 exists. It tries to repair nagios, nagiosxi, and nagiosql. Nagiosxi and nagiosql do not exist so they error when trying to be repaired. Going through the Ndoutils install these databases are never mentioned.
I'm able to connect to nagios through putty without issue, just can't access XI through the web interface. I went through this guide https://support.nagios.com/kb/article/n ... ce-25.html and it didn't resolve the issue. Any guidance would be greatly appreciated.
Re: NagiosXI Web Interface not working after Ndoutils instal
NDO is included in Nagios XI... Why were you trying to install it again?! I would recommend that you start "clean" by doing new, fresh install of Nagios XI 5.7.3. Do not try to install NDOutils afterwards!
Here's our official installation guide:
https://assets.nagios.com/downloads/nag ... -Linux.pdf
