Is there a way to specify the SSH port to use while deploying the NCPA agent in XI 5.7.2 or higher?
Also, after deploying Nagios XI NCPA agent, the screen says "Please wait for job to finish. Once finished, you can select the hosts run the configuration wizard against." It should say "Please wait for job to finish. Once finished, you can select the hosts to run the configuration wizard against." (bolding mine).
NCPA Deployment port and typo
Re: NCPA Deployment port and typo
There is no way to specify a custom port under the "Deploy Agent" page. I filed an internal feature request on your behalf for adding this functionality.Is there a way to specify the SSH port to use while deploying the NCPA agent in XI 5.7.2 or higher?
I also filed a bug report on the typo (task_id=15336). Thanks for reporting this!
You are welcome!
