INSTALL: POST-INSTALL: Nagios Core post install running...
System has not been booted with systemd as init system (PID 1). Can't operate.
Failed to connect to bus: Host is down
ERROR: Subcomponent 'nagioscore' installation failed - exiting.
Subcomponents installation failed - exiting
RESULT=1
INSTALLATION ERROR!
in your communications with Nagios XI technical support.
The script that failed was: './A-subcomponents'
turkcan.keskin wrote:Dear authorized,
I do a clean install on the ubuntu docker image but I get the error, "The script that failed was: './A-subcomponents'"
The document i'm following: : assets.nagios.com/downloads/nagiosxi/docs/Installing-Nagios-XI-Manually-on-Linux.pdf
RESULT=1
INSTALLATION ERROR!
Nagios XI cannot be installed on Docker, it needs to be on a full Linux environment
