I have 2 things to ask.
1.) I just noticed that my Service list sort order is now putting all the Upper case in a group before the Lower case names.
I am okay with this but wondered if that is intentional.
Previously, "OV*" would come after "hps*". In the new 5.7.3 it is listed before, with all the other upper case services.
2.)
I also noticed something that I DO care about.
The search in the black menu strip still does the look ahead as you type in a name. It provides you with items to choose from a list. If you do use it, you only get a Host Status of the item selected. As such I tend not to use it. I like to see all the services.
I prefer to use the white search in the Service Status to select. I used to get 10 items to choose from.
The search in the Service Status page no longer does a look ahead. It no longer populates the screen with host names as you type. It only uses the web browser history for that form search box. I used to be able to select the server of my choice there. This I see as a downgrade. Was this intentional?
Please advise.
Steve B
Sort difference in new version and difference in Searching
SteveBeauchemin
XI 5.7.3 / Core 4.4.6 / NagVis 1.9.8 / LiveStatus 1.5.0p11 / RRDCached 1.7.0 / Redis 3.2.8 /
SNMPTT / Gearman 0.33-7 / Mod_Gearman 3.0.7 / NLS 2.0.8 / NNA 2.3.1 /
NSClient 0.5.0 / NRPE Solaris 3.2.1 Linux 3.2.1 HPUX 3.2.1
Re: Sort difference in new version and difference in Searchi
#1 has to do with the change in NDO and the sorting and I don't think there is much to be done about it but I brought it up to the developers.
#2 I confirmed is a bug, and it will be fixed in the next release of XI
SteveBeauchemin
Thank you Scott.
Was just wondering.
You can close this.
Steve B
Was just wondering.
You can close this.
Steve B
Closing threadSteveBeauchemin wrote:Thank you Scott.
Was just wondering.
You can close this.
Steve B
