DISK CRITIKAL: No such file or directory
stbender
Post by stbender »
I want to monitor an ubuntu server 12.04 installation with 3 disks.
Here's the disk configuration from "df":
/dev/md1         78G    4,1G   70G    6% /
/dev/sdc1        19T     84G   18T    1% /mnt/images
/dev/sdc2       2,0T     30G  1,8T    2% /mnt/db
I set up theses Nagios services:
        host_name                       server
        service_description             Disk Space /
        check_command                   check_disk!20%!10%!/
        host_name                       server
        service_description             Disk Space Images
        check_command                   check_disk!20%!10%!/mnt/images
        host_name                       server
        service_description             Disk Space DB
        check_command                   check_disk!20%!10%!/mnt/db
The first service for "/" gives a correct status.
The other two services give me an error: "DISK CRITICAL - /mnt/db is not accessible: No such file or directory "
Am I doing something wrong?
Thank you!
Best regards,
Stephan
agriffin
Re: DISK CRITIKAL: No such file or directory
Post by agriffin »
Does the nagios user have read permissions on /mnt/db?
stbender
Post by stbender »
well, I guess he does.
doing ls -la /mnt/ I get:
drwxr-xr-x  4 root root 4096 Jun  1 16:47 db
drwxr-xr-x  4 pacs root 4096 Mai 31 16:44 images
So from "drwxr-xr-x" I assume every user has at least the read permission.
agriffin
Post by agriffin »
How about read access to /mnt? Are you running anything like SELinux that might add additional restrictions on top of regular file permissions?
stbender
Post by stbender »
ok, there was a problem with the communication between nagios server and the nagios process on the side of the monitored system.
Thank you!
agriffin
Post by agriffin »
Okay, glad you got everything working!
matt_h2
Post by matt_h2 »
Hi all.
I have a similar issue to stbender above where all but one filesystem reports back fine. The one that doesn't reports the message:
DISK CRITICAL - XXXXX is not accessible: No such file or directory
I've checked to make sure the filesystem and directories are readable by everyone and I'm not running selinux.
I can run the following command locally on the monitoring server which reports back successfully:
/usr/local/nagios/libexec/check_nrpe -H NN.NN.NN.NN -c check_disk -a w20 c10 XXXXX
DISK OK - free space: XXXXX 23710 MB (99% inode=99%);| XXXXX=206MB;25197;25197;0;25197
Can anyone help and/or give me some ideas of things to check please?
Regards
Matt
Post by Box293 »
Can you please show us the service definition and also the command definition this service uses.
matt_h2
Post by matt_h2 »
Service definition:
host_name HHHHH
service_description Partition PPPPP
check_command check_nrpe_disk!20%!10%!PPPPP
Command definition:
command_name check_nrpe_disk
command_line $USER1$/check_nrpe -H $HOSTADDRESS$ -p5666 -c check_disk -a $ARG1$ $ARG2$ $ARG3$
Obviously where: HHHHH is our hostname and PPPPP is the mount point.
Post by Box293 »
On your remote system, when you execute this locally what output does it produce?
su nagios
/usr/local/nagios/libexec/check_disk -w w20% -c c10% PPPPP
Make sure this is executed as the user nagios.
