Hi All,
We are attempting to use auto-discovery scans however they fail to execute, the jobs status remains in a "waiting" state. Manual executions of the "Once" jobs works fine.
Nagios Version - 5.6.10
OS Version: RHEL 7.7
SELinux: Disabled
I did find the following post https://support.nagios.com/forum/viewto ... 16&t=54184 which mentioned changing permissions on the jobs dir, re-creating the scheduled jobs however this has failed to make a difference.
The permissions prior to this were 776 on the jobs dir, i changed to 775 which i didn't suspect to make a difference.
[nagios@monprdappla005 autodiscovery]$ ls -la
total 64
drwxr-xr-x 4 nagios nagios 115 Sep 11 2019 .
drwxr-xr-x 64 nagios nagios 4096 Sep 11 2019 ..
-rw-r--r-- 1 nagios nagios 12800 Sep 11 2019 autodiscovery.inc.php
-rw-r--r-- 1 nagios nagios 2329 Sep 11 2019 CHANGES.TXT
drwxr-xr-x 2 nagios nagios 31 Sep 11 2019 images
-rw-r--r-- 1 nagios nagios 39584 Sep 11 2019 index.php
-rwxr-xr-- 1 nagios nagios 0 Sep 11 2019 install.sh
drwxrwxr-x 2 nagios nagios 62 Sep 22 14:02 jobs
I did find some errors in /var/log/httpd
# tail error_log
cat: write error: Broken pipe
You (apache) are not allowed to use this program (crontab)
See crontab(1) for more information
# tail ssl_error_log
[Thu Sep 24 08:42:01.764310 2020] [:error] [pid 29691] [client 10.241.160.6:55038] PHP Warning: filemtime(): stat failed for /usr/local/nagiosxi/html/includes/components/autodiscovery/jobs/pAHv9d.out in /apps/nagiosxi/html/includes/components/autodiscovery/index.php on line 286, referer: https://<hostname removed>/nagiosxi/includes/components/autodiscovery/?
Nagios XI auto-discovery scheduled job "waiting"
oskargaboda
oskargaboda
Re: Nagios XI auto-discovery scheduled job "waiting"
FYI, issue resolved it was our SOE having a /etc/cron.allow and the apache user not being allowed to setup the scheduled jobs .
benjaminsmith
Regards,
Benjamin
Fabulous! Glad to hear you got it fixed and thanks for sharing the solution.FYI, issue resolved it was our SOE having a /etc/cron.allow and the apache user not being allowed to setup the scheduled jobs
Regards,
Benjamin
