Hi
I have started noticing this on our Windows Servers
CHECK_NRPE: Invalid packet version received from server.
I have upgraded the NSClient Agent to what I think is the latest version
NSCP-0.5.2.35-x64.msi
But I still get the message
The only way to get the Windows systems to report correct is by editing the check_nrpe command to
$USER1$/check_nrpe -2 -H $HOSTADDRESS$ -t 30 -c $ARG1$ $ARG2$
Adding the -2
benjaminsmith
Re: CHECK_NRPE: Invalid packet version received from server.
If you have to make the changes across of a number of hosts or services, the Bulk Mods tool is helpful here.
-- Benjamin
Reference:
https://support.nagios.com/kb/article/n ... s-786.html
If you're running the later version of check_nrpe, you'll need to add this option since we've updated the TCP packet structure in version 4, and adding this will use the older packet types.The only way to get the Windows systems to report correct is by editing the check_nrpe command to
-- Benjamin
Reference:
Hi Benjamin
Thanks I will just leave the -2 in there as its all working
thanks
thanks
Sounds goodmccrakem wrote:Hi Benjamin
thanks
Locking thread
