Rhel 5 false alerts on nagios core 4.4.5
Rajagopal.d
Post by Rajagopal.d »
Can anyone help me with nagios check issue
Created shell script to monitor the root password expiry, The plugin working fine on the nrpe client server below is the output
/usr/lib64/nagios/plugins/check_pwd_expire
WARNING: Days until root password expiry = 57
When i try to call the same nrpe command from the nagios server, its throwing a false alert in server as well as on nagios Dashboard
Below is the false output from nagios server (check_pwd is the nrpe command for above script)
/usr/lib64/nagios/plugins/check_nrpe -H <HostName> -c check_pwd
OK: Days until root password expiry =
Can anyone help me to fix this issue
Thanks in advance
gormank
Re: Rhel 5 false alerts on nagios core 4.4.5
Post by gormank »
Are you testing the check as root or nagios? You may need to add it to a file in /etc/sudoers.d if it fails as nagios.
Rajagopal.d
Hi Gormank,
Thanks, the issue is resolved now, i have added the nagios user in sudoers file. Its working fine now.
Thanks alot
Rajagopal.d wrote:Hi Gormank,
Thanks alot
Great!
Locking thread
