Dear Sir,
I need a favour from you that I have lots of server more then 300 so I need to monitor of all servers which up or down and also which service is up or down. so without using GUI mode I want to add host by using CMD. so can you tell the easy way how can i easily add lots of host without using GUI bcz use GUI its takes lots of time
Ismail
Automatic Host add by uploading file
benjaminsmith
Re: Automatic Host add by uploading file
Hi Ismail,
Thanks for trying out Nagios XI!
In this situation, the Bulk Host Cloning and Import Wizard can save a lot of time and it's easy to use. The following guide contains step-by-step instructions.
How To Use The Bulk Host Cloning And Import Wizard
Take a look at the guide and let me know if that would work for you.
-- Benjamin
-- Benjamin
