Nagios XI Server config wizard
kalyanpabolu
Post by kalyanpabolu »
Hi team,
We are trying to monitor one Nagios server from another Nagios server using Nagios XI Server config wizard. We are getting below error:
Error: Could not parse JSON from http://10.44.3.8/ ()
Could you please help here?
benjaminsmith
Re: Nagios XI Server config wizard
Post by benjaminsmith »
It's possible that it is just timing out before it's getting any data back, you can edit the check in the CCM and add the following option
--timeout=30
See: Using The Core Config Manager For Service Management
If that does not resolve the error, please run the following check from the command line and post the output. Thanks, Benjamin
/usr/bin/php /usr/local/nagios/libexec/check_nagiosxiserver.php --url='http://192.168.42.3/nagiosxi/' --apikey='APIKEY' --mode=daemons --debug=1
kalyanpabolu
Adding timeout in command definition didn't help.
Below is the output of another command.
[root@vmaz-nagiosxi ~]# /usr/bin/php /usr/local/nagios/libexec/check_nagiosxiserver.php --url='http://10.44.3.8/' --apikey='*********************************' --mode=daemons --debug=1
ACCESSING URL: http://10.44.3.8//api/v1/system/statusdetail?
apikey=************************************
RESULT:
Array
[headers] => Array
[Status] => 404
[body] =>
[info] => Array
[url] => http://10.44.3.8//api/v1/system/statusdetail?
apikey=****************************************************
[content_type] => text/html; charset=iso-8859-1
[http_code] => 404
[header_size] => 176
[request_size] => 177
[filetime] => -1
[ssl_verify_result] => 0
[redirect_count] => 0
[total_time] => 0.000488
[namelookup_time] => 2.3E-5
[connect_time] => 0.000116
[pretransfer_time] => 0.000175
[size_upload] => 0
[size_download] => 224
[speed_download] => 224000
[speed_upload] => 0
[download_content_length] => 224
[upload_content_length] => -1
[starttransfer_time] => 0.000459
[redirect_time] => 0
[redirect_url] =>
[primary_ip] => 10.44.3.8
[certinfo] => Array
[primary_port] => 80
[local_ip] => 10.44.3.8
[local_port] => 55794
benjaminsmith
HI,
Thanks for running that command, it's getting an HTTP error. Could there by a proxy running or firewall getting in the way.
Are you able to ping the XI server?
ping <ip address>
Can you run a nmap to check the ports open on that address as well?
nmap <ip address>
Thanks, Benjamin
kalyanpabolu
Below is the output:
[root@HO1-NAGIOSXI ~]# ping 10.44.3.8
PING 10.44.3.8 (10.44.3.8) 56(84) bytes of data.
64 bytes from 10.44.3.8: icmp_seq=1 ttl=61 time=125 ms
64 bytes from 10.44.3.8: icmp_seq=2 ttl=61 time=125 ms
64 bytes from 10.44.3.8: icmp_seq=3 ttl=61 time=125 ms
^C
--- 10.44.3.8 ping statistics ---
4 packets transmitted, 3 received, 25% packet loss, time 5ms
rtt min/avg/max/mdev = 125.221/125.317/125.468/0.108 ms
[root@HO1-NAGIOSXI ~]# nmap 10.44.3.8
Starting Nmap 7.70 ( https://nmap.org ) at 2020-10-01 19:02 +04
Nmap scan report for 10.44.3.8
Host is up (0.13s latency).
Not shown: 995 closed ports
PORT STATE SERVICE
22/tcp open ssh
80/tcp open http
443/tcp open https
3306/tcp open mysql
9090/tcp open zeus-admin
Nmap done: 1 IP address (1 host up) scanned in 3.67 seconds
[root@vmaz-nagiosxi ~]# ping 10.1.0.220
PING 10.1.0.220 (10.1.0.220) 56(84) bytes of data.
64 bytes from 10.1.0.220: icmp_seq=1 ttl=61 time=125 ms
64 bytes from 10.1.0.220: icmp_seq=2 ttl=61 time=125 ms
64 bytes from 10.1.0.220: icmp_seq=3 ttl=61 time=125 ms
64 bytes from 10.1.0.220: icmp_seq=4 ttl=61 time=125 ms
^C
--- 10.1.0.220 ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 7ms
rtt min/avg/max/mdev = 125.068/125.121/125.174/0.434 ms
[root@vmaz-nagiosxi ~]# nmap 10.1.0.220
Starting Nmap 7.70 ( https://nmap.org ) at 2020-10-01 19:03 +04
Nmap scan report for 10.1.0.220
Not shown: 996 filtered ports
PORT STATE SERVICE
22/tcp open ssh
80/tcp open http
443/tcp open https
Nmap done: 1 IP address (1 host up) scanned in 43.15 seconds
benjaminsmith
Perfect, that looks good. What version is this XI server running? The API functionality might not be available on this system.
Benjamin
pingreply
Post by pingreply »
I just had the same issue. The problem is that the script tries to get data from /api/v1..<etc>
But current location is /nagiosxi/api/v1..<etc>
I changed it in the php-file and this works on my side.
Regards, Edwin
kalyanpabolu
We are using Nagios XI 5.7.3.
benjaminsmith
@@pingreply, Thank you!
Let's just make sure you have the latest version of the Nagios XI Server wizard, it should be 1.3.3. To confirm this go to Admin > System Extensions > Manage Config Wizards and scroll down to the XI Wizard.
If it's running the latest version, as suggested, try running the following API command to verify if you're able to get a valid return and let us know the results.
curl -XGET "http://<ip_address/nagiosxi/api/v1/system/status?apikey=<the api key>&pretty=1"
kalyanpabolu
[root@HO1-NAGIOSXI ~]# curl -XGET "http://10.1.0.220/api/v1/system/status? ... ********=1"
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>404 Not Found</title>
</head><body>
<h1>Not Found</h1>
<p>The requested URL /api/v1/system/status was not found on this server.</p>
</body></html>
