Error: (0) json_encode(): Invalid UTF-8 sequence in argument
el.tison
Post by el.tison »
Hello support team,
Since a recent NagiosXI update, none of our Nagvis maps works.
Here is the error message:
URL: /nagvis/server/core/ajax_handler.php?mod=Map&act=getMapObjects&show=GTLD&header_menu=1&hover_menu=1&context_menu=1&zoom=100&_ajaxid=1601368696
File: /usr/local/nagvis/share/server/core/classes/NagVisMap.php
Line: 116
#0 [internal function]: nagvisExceptionErrorHandler(2, 'json_encode(): ...', '/usr/local/nagv...', 116, Array)
#1 /usr/local/nagvis/share/server/core/classes/NagVisMap.php(116): json_encode(Array)
#2 /usr/local/nagvis/share/server/core/classes/CoreModMap.php(322): NagVisMap->parseObjectsJson()
#3 /usr/local/nagvis/share/server/core/classes/CoreModMap.php(105): CoreModMap->getMapObjects()
#4 /usr/local/nagvis/share/server/core/functions/index.php(120): CoreModMap->handleAction()
#5 /usr/local/nagvis/share/server/core/ajax_handler.php(59): require('/usr/local/nagv...')
#6 {main}
Do you have a lead to help us?
benjaminsmith
Re: Error: (0) json_encode(): Invalid UTF-8 sequence in argu
Post by benjaminsmith »
Let's add the following option to the database configuration file. Edit the /etc/my.cnf and under the [mysqld] section add this line:
init-connect='SET NAMES utf8'
Then restart the services and let me know if the issue is resolved.If not, what operating system are you currently using with Nagios XI.
systemctl stop nagios
systemctl restart mariadb
systemctl start nagios
Regards,
Benjamin
el.tison
Post by el.tison »
Awesome, it works!
Thank you
el.tison wrote:Awesome, it works!
Thank you
Great!
Locking thread
