question about configuration changes.
benhank
Post by benhank »
I have been given a slim window to make changes to my nagios production server.
It has been suggested that I go thru configuration\core config manager\ and then make any changes needed, then wait a couple of hours and hit apply changes.
i think this may cause me issues, any suggestions?
Proudly running:
Nagios Network Analyser
Nagios Fusion
Re: question about configuration changes.
If you make configuration changes in the core config manager they will not be applied until you click apply configuration.
benhank
Post by benhank »
I know, but they want me want me to save my changes and click apply changes an hour or two later.
Proudly running:
Nagios Fusion
That's not a problem at all.
If you save the changes, they are stored in the configuration database, but aren't used until the next "apply configuration" is done.
benhank
Post by benhank »
thanks scott!
Proudly running:
Nagios Fusion
no problem.
