Receiving the following error when trying to install NagiosXI Current version on Centos 8.
Installing Nagios XI base files...
Creating product directory...
./B-installxi: line 104: /etc/php-fpm.d/www.conf: No such file or directory
[root@Nagios-XI nagiosxi]# ./B-installxi: line 104: /etc/php-fpm.d/www.conf: No such file or directory
bash: ./B-installxi:: No such file or directory
[root@Nagios-XI nagiosxi]# ls -l /etc/php-fpm.d/www.conf
ls: cannot access '/etc/php-fpm.d/www.conf': No such file or directory
[root@Nagios-XI nagiosxi]# dnf install php-fp
Last metadata expiration check: 0:05:42 ago on Tue 29 Sep 2020 02:12:44 PM UTC.
No match for argument: php-fp
Error: Unable to find a match: php-fp
Its appears NagiosXI did not install the php-fp and also cannot find it to install??
Install error on Centos 8
Re: Install error on Centos 8
Manually installed php-fm and installation completed. I hope though this does not cause any future update issues.
benjaminsmith
Glad to hear you got it solved. No, that should be fine now, and not sure why the install script wasn't able to add the package on the first try.
Let us know if it's ok to close this thread out.
Best Regards,
Benjamin
Best Regards,
Benjamin
