I am attempting to pull in the hoststatus via API and get hostnames of servers where the active_checks_enabled=0.
I used to be able to run the following:
curl -XGET -k -s https://SERVER/nagiosxi/api/v1/objects/hoststatus?apikey=KEY&active_checks_enabled=0&pretty=1 | grep \"host_name\":
Now, I just get an unformed response for the curl command. Did something change in how Nagios responds to a curl?
Running RHEL 7.8 VM's and Nagios XI 5.7.3
API not returning pretty JSON
Re: API not returning pretty JSON
I'm getting the pretty output. Just a quick thing I noticed, though, your command posted here doesn't have quotes around it. When I copied and pasted into my environment, replaced the XI IP and API key, I did get big, ugly output. Can you confirm that the command you're running looks more like this?
curl -XGET -k -s "https://SERVER/nagiosxi/api/v1/objects/hoststatus?apikey=KEY&active_checks_enabled=0&pretty=1" | grep \"host_name\":As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
Thanks, that worked.
