Hello I have a proble with a monitoring service in nagios.log
Nagios XI is intalled in RHEL 8
NDO-3: Note: preceding query is longer than allowed according to maximum SQL buffer size.
the query excecuted its a insert in nagios_servicestatus and total query lenght its 26956 characters
INSERT INTO nagios_servicestatus (instance_id, service_object_id, status_update_time, output, long_output, perfdata, current_state, has_been_checked, should_be_scheduled, current_check_attempt, max_check_attempts, last_check, next_check, check_type, check_options, last_state_change, last_hard_state_change, last_hard_state, last_time_ok, last_time_warning, last_time_unknown, last_time_critical, state_type, last_notification, next_notification, no_more_notifications, notifications_enabled, problem_has_been_acknowledged, acknowledgement_type, current_notification_number, passive_checks_enabled, active_checks_enabled, event_handler_enabled, flap_detection_enabled, is_flapping, percent_state_change, latency, execution_time, scheduled_downtime_depth, failure_prediction_enabled, process_performance_data, obsess_over_service, modified_service_attributes, event_handler, check_command, normal_check_interval, retry_check_interval, check_timeperiod_object_id)
NDO 3 Error
Re: NDO 3 Error
Since this a database related error, I would recommend running the database check and repair script to verify that there are no issues there. Log in as root and run the following command:
Secondly, besides the error message in the nagios.log, what other behavior are you noticing? Are check results getting processed in the GUI and notifications working?
Lastly, please PM the system profile along with the /etc/my.cnf (database configuration) file.
Benjamin
/usr/local/nagiosxi/scripts/repair_databases.sh
Benjamin
Re: NDO 3 Error
Hello @benjaminsmith, the repair database is executed and mysqlcheck -f -r -u root -pnagiosxi --all-databases in both cases the error persist,benjaminsmith wrote:Hi,
Secondly, besides the error message in the nagios.log, what other behavior are you noticing? Are check results getting processed in the GUI and notifications working?Code: Select all
Benjamin
for some strange reason I can't see the services without filter, but putting filter on the services I can see them
I have executed this query to view output
https://support.nagios.com/kb/article/n ... s-478.html
The Backup not function correctly, only function in database if I add --no-tablespaces in backup script
Re: NDO 3 Error
Since you're running EL8, make sure you set your mysql sql_mode="". Try adding max_allowed_packet=512M as well.
Edit this file:
Add these under the [mysqld] section:
Then restart mysql:
Now test again.
If that doesn't work, send the output of this command:
Edit this file:
/etc/my.cnf.d/mysql-server.cnf
sql_mode=""
systemctl restart mysqld
mysql -h 127.0.0.1 -uroot -pnagiosxi nagios -e "desc nagios_servicestatus;desc nagios_hoststatus;"
Re: NDO 3 Error
ssax wrote:Since you're running EL8, make sure you set your mysql sql_mode="". Try adding max_allowed_packet=512M as well.
Edit this file:
Add these under the [mysqld] section:Code: Select all
Then restart mysql:Code: Select all
sql_mode="" max_allowed_packet=512M
Now test again.Code: Select all
Hello @ssax
the error seems to be no longer present, but it did not work to be able to see all the elements in service
To see all the elements in service I had to add in my.cnf
sort_buffer_size=512K
Re: NDO 3 Error
Thank you for posting the update and your resolution, I have let our QA/Dev team know about your changes. Let us know when we're okay to lock this up and mark it as resolved.
