I recently moved over to CentOS 7 from CentOS 6 and I have only just noticed that the performance graphs are no longer working. I have tried the usual fixes. for instance if graphs ever stopped on our CentOS 6 this following code used to fix the issue.
service rrdcached stop
rm -f /usr/local/nagiosxi/rrdcache/*
service rrdcached start
[root@nagxi01 nagiosxi]# systemctl restart rrdcached.service
Failed to restart rrdcached.service: Unit not found.
[root@nagxi01 nagiosxi]# yum install rrdtool
Loaded plugins: fastestmirror
Determining fastest mirrors
Package matching rrdtool-1.4.8-9.el7.x86_64 already installed. Checking for update.
Nothing to do
Performance Data: 'C: free'=1.99717G;2;0.8789;0;29.99039 'C: free %'=7%;7;3;0;100Code: Select all
[root@nagxi01 rrdcache]# ls -l
total 0
[root@nagxi01 nagiosxi]# ls /usr/local/nagios/var/spool/perfdata/ | wc -l
8
6
As you can see from this screenshot, nothing appear to be wrong.
This info may also help.
[root@nagxi01 ~]# tail -25 /usr/local/nagios/var/perfdata.log
2020-10-06 16:52:16 [8002] [2] Template is check_xi_host_ping.php
2020-10-06 16:52:16 [8002] [2] data2rrd called
2020-10-06 16:52:16 [8002] [2] RRDs::update --daemon=unix:/var/rrdtool/rrdcached/rrdcached.sock /usr/local/nagios/share/perfdata/HANS02-01/_HOST_.rrd 1601999531:0.159:0:0.299:0.107
2020-10-06 16:52:16 [8002] [1] RRDs::update ERROR Unable to connect to rrdcached: No such file or directory
2020-10-06 16:52:16 [8002] [2] Processing Line 239
2020-10-06 16:52:16 [8002] [2] Datatype set to 'HOSTPERFDATA'
2020-10-06 16:52:16 [8002] [1] Found Performance Data for CORP03 / _HOST_ (rta=0.133ms;3000.000;6000.000;0; pl=0%;80;100;0;100 rtmax=0.258ms;;;; rtmin=0.084ms;;;;)
2020-10-06 16:52:16 [8002] [2] No Custom Template found for check_xi_host_ping (/usr/local/nagios/etc/pnp/check_commands/check_xi_host_ping.cfg)
2020-10-06 16:52:16 [8002] [2] RRD Datatype is GAUGE
2020-10-06 16:52:16 [8002] [2] RRDs::update --daemon=unix:/var/rrdtool/rrdcached/rrdcached.sock /usr/local/nagios/share/perfdata/CORP03/_HOST_.rrd 1601999531:0.133:0:0.258:0.084
2020-10-06 16:52:16 [8002] [1] 239 Lines processed
2020-10-06 16:52:16 [8002] [1] /usr/local/nagios/var/spool/perfdata//host-perfdata.1601999531-PID-8002 deleted
2020-10-06 16:52:16 [8002] [1] PNP exiting (runtime 0.184933s) ...
[root@nagxi01 ~]# tail -25 /usr/local/nagios/var/npcd.log
[10-06-2020 16:53:10] NPCD: File 'service-perfdata.1561995007-PID-8830' is an already in process PNP file. Leaving it untouched.
[10-06-2020 16:53:10] NPCD: No more files to process... waiting for 6 seconds
[10-06-2020 16:53:16] NPCD: File 'host-perfdata.1561995007-PID-8829' is an already in process PNP file. Leaving it untouched.
[10-06-2020 16:53:16] NPCD: File 'host-perfdata.1561995210-PID-7554' is an already in process PNP file. Leaving it untouched.
[10-06-2020 16:53:16] NPCD: File 'host-perfdata.1561995225-PID-7546' is an already in process PNP file. Leaving it untouched.
[10-06-2020 16:53:16] NPCD: File 'host-perfdata.1561995271-PID-7555' is an already in process PNP file. Leaving it untouched.
[10-06-2020 16:53:16] NPCD: File 'host-perfdata.1561995292-PID-7549' is an already in process PNP file. Leaving it untouched.
[10-06-2020 16:53:16] NPCD: File 'service-perfdata.1561995007-PID-8830' is an already in process PNP file. Leaving it untouched.
[10-06-2020 16:53:16] NPCD: No more files to process... waiting for 6 seconds
[10-06-2020 16:53:22] NPCD: File 'host-perfdata.1561995007-PID-8829' is an already in process PNP file. Leaving it untouched.
[10-06-2020 16:53:22] NPCD: File 'host-perfdata.1561995210-PID-7554' is an already in process PNP file. Leaving it untouched.
[10-06-2020 16:53:22] NPCD: File 'host-perfdata.1561995225-PID-7546' is an already in process PNP file. Leaving it untouched.
[10-06-2020 16:53:22] NPCD: File 'host-perfdata.1561995271-PID-7555' is an already in process PNP file. Leaving it untouched.
[10-06-2020 16:53:22] NPCD: File 'host-perfdata.1561995292-PID-7549' is an already in process PNP file. Leaving it untouched.
[10-06-2020 16:53:22] NPCD: File 'service-perfdata.1561995007-PID-8830' is an already in process PNP file. Leaving it untouched.
[10-06-2020 16:53:22] NPCD: Processing file 'host-perfdata.1601999591'
[10-06-2020 16:53:22] NPCD: Processing file 'service-perfdata.1601999592'
[10-06-2020 16:53:22] NPCD: No more files to process... waiting for 6 seconds
[10-06-2020 16:53:28] NPCD: File 'host-perfdata.1561995007-PID-8829' is an already in process PNP file. Leaving it untouched.
[10-06-2020 16:53:28] NPCD: File 'host-perfdata.1561995210-PID-7554' is an already in process PNP file. Leaving it untouched.
[10-06-2020 16:53:28] NPCD: File 'host-perfdata.1561995225-PID-7546' is an already in process PNP file. Leaving it untouched.
[10-06-2020 16:53:28] NPCD: File 'host-perfdata.1561995271-PID-7555' is an already in process PNP file. Leaving it untouched.
[10-06-2020 16:53:28] NPCD: File 'host-perfdata.1561995292-PID-7549' is an already in process PNP file. Leaving it untouched.
[10-06-2020 16:53:28] NPCD: File 'service-perfdata.1561995007-PID-8830' is an already in process PNP file. Leaving it untouched.
[10-06-2020 16:53:28] NPCD: No more files to process... waiting for 6 seconds
As when i check this part
Verifying The Setup
The rrdcached configuration options are defined in the /etc/sysconfig/rrdcached file on RHEL,
CentOS, and Oracle Linux systems. On Debian and Ubuntu, they are defined in the
/etc/default/rrdcached file. Code: Select all
[root@nagxi01 var]# cd /etc/sysconfig/rrdcached
-bash: cd: /etc/sysconfig/rrdcached: No such file or directory
You have new mail in /var/spool/mail/root
