Custom monitoring using Nagios
kgopiramesh_25
Post by kgopiramesh_25 »
Hi everyone,
We have created custom monitor and it will take host name / IP address as argument and while running manually it is working fine but when configuring as service, it is throwing error and Nagios is not getting started. PFB details.
command definition :
command_name check_proc_count
command_line /usr/local/nagios/libexec/check_proc_count_nt $ARG1$
service definition :
host_name testhost
service_description testing
check_command check_proc_count testhost
gormank
Re: Custom monitoring using Nagios
Post by gormank »
Nagios runs checks as the nagios user by default so when running manually you want to do so as nagios.
It would help if we could see output of the check run manually on the test host and via nrpe/ncpa from the nagios host, including the command prompt and command.
snapier3
Post by snapier3 »
Make sure the file is executable and owned by the nagios user.
"chmod +x yourscript.sh'
"chown nagios:nagios yourscript.sh"
When testing on the system you will want to run this as the nagios user.
"su nagios"
Now you will execute the command
"./yourscript.sh arg"
If the script functions properly you will receive 1 line of output on the console.
benjaminsmith
Post by benjaminsmith »
@snapier3 and @gormank Thanks!
@ kgopiramesh_25 Did you get it working? Let us know.
