check_docker cpu provide inconsistent values to Nagios
sslimani
Post by sslimani »
I use the script "https://github.com/timdaman/check_docke ... _docker.py" for check_docker, but I think there is a problem with CPU % calculation, because the reporting value in nagios does not correspond to to the real value,
Please if you have used this script and fixed this problem, can you help me please?
cdienger
Re: check_docker cpu provide inconsistent values to Nagios
Post by cdienger »
This isn't a plugin that we've developed so our ability to help will be limited. It looks like it was last updated 12 days ago though - are you using the most recent version? If you think this is a bug it would be best to bring this to the attention of the author and submit an issue at https://github.com/timdaman/check_docker/issues.
