Autofs Mount Point Monitoring
s.diwakar1
Post by s.diwakar1 »
Hi All,
Hope you are doing well!!!
I am using Nagios Core 4.4.5 version.
I want to monitor mount points from /etc/fstab and if they are mounted.
Do we have any script to monitor this which is compatible with Nagios Core 4.4.5 Version?
Thanks in advance!!!
Regards,
Diwakar Sharma
Thanks & Regards,
Diwakar Sharma
gormank
Re: Autofs Mount Point Monitoring
Post by gormank »
Have a look at check_disk or search the internet for something like nagios check fstab...
