Warning not counted in configuration apply, FYI
Bitflogger
Post by Bitflogger »
Hello, I'm running 5.6.14 on a 64-bit VM CentOS 7 system.
I tend to use the end key to see the warning and critical counts of the configuration apply results e-mail. I was surprised to find out I had a warning that was not counted. And I did not see it for a while because of my use of the end key.
The output comes from a cron job: 05 7,12,17 * * 1-5 nagios /usr/local/nagiosxi/scripts/reconfigure_nagios.sh
FYI, you can lock the call.
Earl
No entry for terminal type "unknown";
using dumb terminal settings.
--- reset_config_perms.sh ------------
> Setting script permissions
> Setting CCM script permissions
> Setting special script permissions
> Setting special component script permissions Setting configuration
> file/directory permissions Setting perfdata directory and RRD
> permissions Setting libexec directory permissions Setting Nagios XI
> config permissions Setting NOM checkpoint user:group permissions
> + Setting Nagios Core corelog.newobjects user:group permissions
> + Setting CCM configuration file user:group permissions Setting
> + Recurring Downtime file user:group permissions Setting BPI
> + configuration file user:group permissions
--- ccm_import.php -------------------
> Setting import directory: /usr/local/nagios/etc/import/ Importing
> config files into the CCM
No files to import
--- ccm_export.php -------------------
> Writing CCM configuration to Nagios files
Finished writing out configuraton
> Verifying configuration with Nagios Core
> Output:
Nagios Core 4.4.5
Copyright (c) 2009-present Nagios Core Development Team and Community Contributors Copyright (c) 1999-2009 Ethan Galstad Last Modified: 2019-08-20
License: GPL
Reading configuration data...
Read main config file okay...
Warning: Duplicate definition found for service 'w_load' on host '****.***.wisc.edu' (config file '/usr/local/nagios/etc/services/w_load_nsclient_05.cfg', starting on line 16)
Checking objects...
Checked 15234 services.
Checked 774 hosts.
Checked 84 host groups.
Checked 9 service groups.
Checked 476 contacts.
Checked 359 contact groups.
Checked 281 commands.
Checked 79 time periods.
Checked 0 host escalations.
Checked 375 service escalations.
Checked 774 hosts
Checked 0 host dependencies
Checked 79 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors: 0
> Return Code: 0
ssax
Dreams In Code
Re: Warning not counted in configuration apply, FYI
Post by ssax »
That is by design, only the warnings/errors from the pre-flight check are counted.
Bitflogger
Ok. So an infinite number of non-preflight warnings are ignored?
I like to keep it completely clean.
Please lock the case.
Earl
ssax
Dreams In Code
Post by ssax »
Correct. if you'd like to submit a feature request for that to be added you can request it here:
https://github.com/NagiosEnterprises/nagioscore/issues
Locking the thread.
