Hello Support,
We need to generate configuration report which should have all the details of the device and its services(For e.g. service thresholds etc). is there any way to pull such data from the configuration files.
Need help to generate configuration report
capgemtools
Supriya
Supriya
benjaminsmith
Re: Need help to generate configuration report
Hi Sandeep,
While there isn't a builtin configuration report, the objects.cache file is very useful for looking up the complete settings for any host or service.
The other option is to pull data from the nagiosql database, contains all of th configurations, but that will require writing the appropriate SQL commands.
Hope that helps answer your question.
Benjamin
/usr/local/nagios/var/objects.cache
Benjamin
