This seems to me to be a bug in the remote HTTP server you're monitoring. The only reason you'd be seeing this is if the server returned a 5xx HTTP response code. Perhaps the code adding the header has a bug in it.
I'd check the following to see what's going on:
- The HTTP server's error logs
- The output from curl -D /dev/stdout [URL], where URL is the URL in the check_http configuration
Why the Plugin Is Returning This
The only way that the plugin could say that there was BOTH a 500 error and a missing string in the output is if the server returned a 5xx HTTP response code AND response body.
For instance, if the URL
http://myhost.example.com/mypage.php returned the following:
HTTP/1.1 500 Internal Server Error
Date: Fri, 16 Oct 2020 18:11:24 GMT
Server: Apache
X-Powered-By: PHP
X-Content-Type-Options: nosniff
Content-Length: 3
Connection: close
Content-Type: text/html; charset=UTF-8
<html>empty example document</html>
and your plugin was looking for
STRING in the
-s flag configuration, then the plugin would give an error message similar to what you're seeing:
/usr/local/nagios/libexec/check_http -I myhost.example.com -S -u /mypage.php -s STRING
HTTP CRITICAL: HTTP/1.1 500 Internal Server Error - string 'STRING' not found on 'https://myhost.example.com/mypage.php' - 271 bytes in 0.110 second response time |time=0.110098s;;;0.000000 size=271B;;;0
Discussion of wages is protected speech under the
National Labor Relations Act, and no employer can tell you you can't disclose your pay with your fellow employees.
