Hello All,
I'm trying to setup Nagios to work with my HP server using ilo card 4
currently the setup is working with SNMP V2, I don't see an option in the plugin to work with SNMP v3
the current check command is : check_hpe_ilo
$USER1$/nagios_hpeilo_engine -H $HOSTADDRESS$ -C $ARG1$ -o $ARG2$
anyone manage to set it up to work with SNMP v3 ?
thank you
Setup Nagios with Hp ILO SNMP v3
benjaminsmith
Re: Setup Nagios with Hp ILO SNMP v3
I would recommend checking the plugin code or running the help options to see if it supports SNMP v3. If not, check the Nagios Exchange for a suitable alternative.
https://exchange.nagios.org/directory/P ... 8Compaq%29
Let us know what you find out.
Benjamin
Benjamin
I would recommend using the redfish interface of the iLO instead of SNMP.
I can also recommend the following check for use with iLO (and/or iBMC & iDRAC):
https://github.com/bb-Ricardo/check_redfish
Regards,
Regards,
D/\N
D/\N
benjaminsmith
@danjoh Thanks for helping out
