All have been successful so far, except the most recent server where we encountered an issue. XI appears to be working, however when navigating to Configure > Core Config Manager > Apply Configuration it warns:
We're able to apply configuration changes and have verified the change is present. However, this warning remains. Applying the configuration as the user, a different user or even having users logout doesn't clear this warning.Users are currently editing objects in the CCM
John Smith is editing a service (started at 2020-10-19 18:19:07)
This issue most likely isn't related to the recent DB name change as we've also re-imported the DB and the CCM warning was present with the same user currently editing three (3) objects in the CCM dating back to 2020-09-17.
Update #1: Prior to starting the next XI Server (Number 7), I thought it would be helpful to confirm there are no pending configuration changes. We're seeing this same behavior.
At this point the Database has not been renamed so we can rule that out as a potential cause. When we Apply Configuration on this Server, the warning remains, but in the config snapshots indicate "Config Ok" with an updated current date/time.Users are currently editing objects in the CCM
John Smith is editing a service (started at 2020-10-19 10:15:05)
Update #2: As described in Update #1, we also see the exact same behavior on Server 8 which is another XI Server we've not changed over yet. Confirming my suspicion an issue was present with CCM prior.
Please advise,
