SLES 15SP2 and NagiosCore 4.4.6
Nagiosmike81
Post by Nagiosmike81 »
yesterday i installed a new SLES Server with SP2 and i make a fresh install of NagiosCore 4.4.6 with NagiosPlugins 2.3.3. now i have troubles with my checks.
I get the Error Code "Return code of 127 is out of bounds. Check if plugin exists" on every checks. I have checked the filepermissions, path's and a lot of other things. no result.
i hope one of you can help me
benjaminsmith
Re: SLES 15SP2 and NagiosCore 4.4.6
Post by benjaminsmith »
Welcome to the Nagios Community Forum. I would check the plugin paths on this system and make sure everything is pointing to the right place.
The main Nagios config file has directives to set the plugin paths.
See: https://assets.nagios.com/downloads/nag ... onfig.html
Check your file permissions on the plugin directory.
ls -l /usr/local/nagios/libexec
Let us know what you find out.
Benjamin
