CHECK_NRPE: Invalid packet version received from server.
scharft
Post by scharft »
hi,
all of our nrpe check's respond with status information: Invalid packet version received from server.
The status itself looks good.
On the XI server is Version: 4.0.3 installed.
All our clients using nsclient 0.5.2 or 0.4.4.19.
i have tried to execute check_nrpe with "-2" it doesn't work for us.
any ideas?
best Regards
cdienger
Re: CHECK_NRPE: Invalid packet version received from server.
Post by cdienger »
Edit the check_nrpe command(or which ever command your config is using) and try this format:
$USER1$/check_nrpe -H $HOSTADDRESS$ -2 -t 30 -c $ARG1$ $ARG2$
I've noticed that the check_nrpe plugin expects the -2 or -3 option prior to the -c command and can throw an error otherwise.
Please provide the full command that you are running along with its output if the above doesn't help you to resolve the issue.
scharft
Post by scharft »
if i use the command you provided without any addtional arguments i got:
[nagios@atvienag001 ~]$ /usr/local/nagios/libexec/check_nrpe -H atviectxpcm851.eumfgat.eumfg.immuno.baxter.com -2 -t 90 -c
NRPE Plugin for Nagios
Version: 4.0.3
Copyright (c) 2009-2017 Nagios Enterprises
1999-2008 Ethan Galstad ([email protected])
Last Modified: 2020-04-28
License: GPL v2 with exemptions (-l for more info)
SSL/TLS Available: OpenSSL 0.9.6 or higher required
If i use it with the arguments we need for:
[nagios@atvienag001 ~]$ /usr/local/nagios/libexec/check_nrpe -H atviectxpcm851.eumfgat.eumfg.immuno.baxter.com -t 90 -c check_powerstate -a $HOSTADDRESS$
cdienger
Post by cdienger »
What is the result of:
/usr/local/nagios/libexec/check_nrpe -H atviectxpcm851.eumfgat.eumfg.immuno.baxter.com -2 -t 90 -c check_powerstate -a $HOSTADDRESS$
Also, are you replacing $HOSTADDRESS$ with a valid host address ?
scharft
Post by scharft »
it is independence which variable or command i useb, the error message ist the same but to answer your question, the variable will be replaced by the fqdn.
[nagios@atvienag001 ~]$ /usr/local/nagios/libexec/check_nrpe -H atviectxpcm851.eumfgat.eumfg.immuno.baxter.com -t 90 -c $_HOSTCTX_DDC$
cdienger
Post by cdienger »
Run this on the command line:
su - nagios
provide a screenshot of the results.
scharft
Post by scharft »
this would be the correct format of the command
./check_nrpe -H atviectxddc051.eumfgdc.eumfg.immuno.baxter.com -2 -t 90 -c check_powerstate -a atviectxrdc001.eumfgdc.eumfg.immuno.baxter.com
result:
[root@atvienag001 libexec]# ./check_nrpe -H atviectxddc051.eumfgdc.eumfg.immuno.baxter.com -2 -t 90 -c check_powerstate -a atviectxrdc001.eumfgdc.eumfg.immuno.baxter.com
Powerstate seems to be OK
your example:
./check_nrpe -H atviectxpcm851.eumfgat.eumfg.immuno.baxter.com -2 -t 90 -c check_powerstate
cdienger
Post by cdienger »
Okay, so now we know that the command will work if given the proper arguments. Please provide a copy of the ccm database so I can take a closer look at the current configuration. Send it to me via a private message.
If the default database is being used then this can be done from the command line with:
mysqldump -uroot -pnagiosxi nagiosql > nagiosql.sql
If the database has been offloaded to another machine then you'll need to modify the commands slightly to look like:
mysqldump -h database_host_ip -uusername -ppassword nagiosql > nagiosql.sql​​
Please provide the nagiosql.sql that is created.
scharft
Post by scharft »
thank you the issue is resolved.
best regards
scharft wrote:Hi,
best regards
Great!
Locking thread
