[program:nagapi]
directory = /home/nagapi
user = api
command = /bin/bash -c "source /home/nagapi/.virtualenvs/nagapi/bin/activate; /home/nagapi/nagios-api/nagios-api"
stdout_logfile = /home/nagapi/supervisor_nagios-api_stdout.log
stderr_logfile = /home/nagapi/supervisor_nagios-api_stderr.log
It seems like the files was not created yet when supervisor tried to run the api the first time. I'm saying this because if i do a supervisorctl reload, everything would reload just fine, and the api would run ok about 50 seconds after the reload command completes.
should i change the command option of the conf file to check for
